Engine ID. - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-13-2010, 01:30 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Engine ID.
I am looking at a old 55 chevy pickup, And i really not sure what engine is in the thing all i know is it has a chevy firing order. The distributor is in the front and slanted to one side. I posted a few pics so maybe someone can help me identify it. Thank's in advance for any help.
Cole
ID:	50800   Click image for larger version
ID:	50801   Click image for larger version
ID:	50802   Click image for larger version
ID:	50803   Click image for larger version
Old 12-13-2010, 02:01 PM
eloc431962's Avatar
Wiki Edits: 37
I have been told by another member here that it's 455 buick engine pre '74 or '75 cause of the point distributor. And i have done alittle research also and i think he hit it right on the head.
Cole
Old 12-13-2010, 02:58 PM
DoubleVision's Avatar
It looks to be a buick or a olds to my eye. While the points distributor could be a sign it`s a older engine, it`s also possible that`s what they used since the ignition system on the truck was already set up for points.
Old 12-13-2010, 03:05 PM
eloc431962's Avatar
Wiki Edits: 37
Thank's DV, I have been doing some searching as i didn't think to get the # off it All i noticed was it had a chevy firing order and looked as stated Buick or olds, I was leaning toward Buick and after looking around, I came down to 350 or 455 Buick and by the valve covers it looks to be a 455.
I do know that the Buick 455 has 5 valve cover bolt's and the Buick 350 has 6.
But not really sure if i can tell %100 percent by the valve covers i can rule out the Buick 350 but i am not sure what other engines have 5 valve cover bolts.
Cole
Old 12-13-2010, 05:41 PM
junior stocker's Avatar
Most definitely a Buick engine. The ribbed valve covers are the biggest, quick glance, give-a-way. Too bad about the broken out rear glass in the truck; it looks to be in pretty good shape other than that.
Old 12-13-2010, 07:29 PM
1930u's Avatar
Last journal entry: 1930u more fuel line plumbing
It is a Buick 1967-1976. It could be a 400, 430, or 455. These things were way under rated given the fact that they were installed in huge cars. A friend of mine had a 430 Wildcat when we were in high school. I could pull him out of the hole with my 64 Impala 340Hp. 409 but once we got rolling 70MPH on it was all over for the Impala.
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 06:57 PM
Build for Hp or Torque? Venturat Engine 76 09-23-2008 10:22 AM
Engine alignment ssmonty Engine 9 07-22-2008 10:10 PM
SF oil???? n-gin Engine 6 07-09-2008 01:37 PM
Why high RPM's on the oval tack? steveyb4342 Engine 25 05-23-2007 07:50 AM
