I have located a GMC engine.The only ID I could find was a L86/NA5 number and it is of the GAR family.The engine was in a 1981 school bus. It also indicated that it is a big block 366 cubic inch and to use 91 octane or higher. I would like to know if this engine has a steel crank and if I could convert it to 427 cubic inches by changing the rod lengths. I would like to use this engine for a marine application or 1/4 mile
drag car. Any info in on this engine would be greatly appreciated, since it is running and almost a freebee. Thanks, |
a 366 is a raised big block truck engine It has very small valves and tiny pistons and cannot be bored to 427 or 396 it is a hi torque low rpm slug and belongs back in that schoolbus, but may have a steel crank
First the steel crank is the same as a 396/427 it will have a wide parting line where the journal centers are lenthwise if its cast the mold line will be thin and have the letters NF cast into the crank second a hi block or tall block has about 3/8 taller deck height than a car block the intake manifold is wider the reason is the pistons were 4 ring design
sugesstion trash it and buy a good motor youll appreciate it in the long run
