engine ID - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-11-2012, 08:35 PM
engine ID
where do i locate engine ID numbers on FORD V8 (possibly 351W)
Old 08-11-2012, 10:52 PM
eagle arm
first you have to find out what type engine it is.
Windsor has the thermostat housing straight out
of the intake manifold.
Cleveland has it on top of cast in timing cover.
M or Modified, i don't know.
casting numbers are usually on side of block or
around distributor.
6090 on right side just means block casting.
have a nice day!
Old 08-11-2012, 11:38 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Here you go. Bottom of page has links to ID casting numbers, etc.
350 Crate Engine: Loud humming sound after engine warms up sofa1515 Engine 2 01-11-2010 06:48 PM
Engine Help. Engine Turns over Hard, like siezed yet runs awsome. Merle9069 Engine 3 10-05-2008 06:38 PM
I need engine mount bracket ideas 1930 chevy with 302 boss engine. Riley Engine 3 07-25-2008 07:29 AM
95 ford F-150 engine swap, Same Transmission fit new engine? F-150 Transmission - Rearend 5 10-07-2007 12:11 PM
say you have a THOUSAND horsepower engine..... (technical engine question inside) lowROLLERchevy Engine 14 02-24-2007 08:26 AM
