engine id - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-03-2002, 02:17 PM
Post engine id
casting # on back of engine-3970010
the number by the alt are whats confusing me-
VO5O2TYZ
C7F451735
if anyone could help me out with this engine id it would be much appreciated.
Old 12-03-2002, 02:29 PM
DoubleVision's Avatar
Post
This is the suffix code I found, 1975 TYZ 350 conv.cab L LS9 165 4 C-10 to 2500 Hope this helps.
Old 12-03-2002, 02:36 PM
awsum34's Avatar
Post
The number V0502TZY V- the motor was assy at Flint MI, the 0502 the motor was built May 2nd, and the TZY the motor was put in converts, c-10 and 2500 trucks. Also it says it's a 350
Old 12-03-2002, 02:39 PM
Post
well thats not at all what i expected, one thing that was odd tho, is the stamp looked brand new, while the rest of the motor looked not so brand new. kind of wierd.
Old 12-03-2002, 03:57 PM
Post
this engine could be a 302 or a 350 used in corvettes,camaros,trucks,passenger cars,chevelles,novas and monte carlos from 69-79.could be a 2 or 4 boltblock. if the suffix code looks new then there is a good chance that its had some work done on it.i've run into this from time to time where poeple don't leave them alone.check the rest of the #s. there should be a # that runs perpendicular to the cast# the first part should be a letter, that will tell you the month it was built,the next will be the day of the month,then the year. if you are not sure just post it and i'll tell you if i can.
Foot to the floor,hair back,knuckles white.
Old 12-03-2002, 04:30 PM
Post
the heads aren't stock, does that mean that the suffix code is wrong?
Old 12-03-2002, 04:42 PM
Post
the suffix code is stamped into the block not the heads
Old 12-03-2002, 04:50 PM
Post
it looks like C273 that was on the passenger side on the back of the block, i could be wrong on those numbers cuz its dark and cold as hell out there.
Old 12-03-2002, 04:53 PM
Post
anyways the guy i bought it off of told me it was a crate motor, a corvette 350. so now i don't know what to think
Old 12-03-2002, 07:42 PM
BOBCRMAN@aol.com's Avatar
Post
the 3970010 blocks were used for many many years starting in 68, they were available as two and four bolt blocks they were used in everything chevy built, also boat motors. cast at Saginaw grey iron casting and trucked to flint engine plant on bristol and van slyke rd. used to watch thousands a day go by. serviced the plant 3 times a week and watched all the operations being done.
Old 12-03-2002, 08:32 PM
Post
is there anyway that this engine could be a crate motor.
Old 12-03-2002, 09:30 PM
Post
yes but an early (before 84) crate motor. check to see if it has the codes stamprd into the pass side front deck between the head and waterpump, crate motors only have one series of numbers as they were never installed into a vehicle, if there are two sets of no.s it came from a factory assembled vehicle. you can then tell what it originally came in by these no's.
Old 12-04-2002, 07:11 PM
New Member
Lightbulb
try going to the website www.yearone.com
on the bottom left of their home page they have a decnet tool to help with VIN, Body, Eng, and other IDs. Maybe it will help. It helped me identify soem parts that taht had been swithed on a car i bought which turned out not to be so all
"ORIGINAL"
Old 12-05-2002, 02:23 PM
Post
march 2,73 what are your head cast #s?
Old 12-05-2002, 02:25 PM
Post
what do you mean cold? does it even get cold down there?
