Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Engine Id numbers
Old 07-17-2012, 04:01 PM
spacytracy's Avatar
spacytracy spacytracy is offline
Last journal entry: 1957 chevrolet truck with firebird subframe
The "plug" on the end of the heads is actually a glued on tag that is intended to melt and fall off should the owner overheat his engine following a rebuild. If the tag is off following engine problems, the rebuilder will void the warranty claiming abuse.
