Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Engine Id numbers
Old 07-17-2012, 03:43 PM
Blacktail Sniper Blacktail Sniper is offline
Originally Posted by spacytracy View Post
The "plug" on the end of the heads is actually a glued on tag that is intended to melt and fall off should the owner overheat his engine following a rebuild. If the tag is off following engine problems, the rebuilder will void the warranty claiming abuse.
Okay, thank you very much. I had never seen anything like this, and this motor is a mystery.
Appreciate the info.
