Engine Id numbers - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-17-2012, 02:52 PM
Engine Id numbers
Anybody willing to help with ID'ing the engine that has this partial VIN & engine code stamped into the front right pad?
Cannont get it narrowed down to one fairly positive answer.
So far, research on the engine number has show as posibilities:
65 Chevy full size
67 Vette
69 Camaro, Chevelle or Nova.
The partial VIN is of no use as nothing I have found has the double "LL" before the unit production number. Only thing I am certain about is that whatever this was, there were 32205 made before it!
The block casting #3858180
Head casting #3890462
Also, the end of each head has what looks like a plug or insert of some type, I have never seen anything like this either, any idea what those are??
Thanks, Dennis
ID:	66809   Click image for larger version
Old 07-17-2012, 03:01 PM
spacytracy's Avatar
Last journal entry: 1957 Chevrolet 3100 Truck Small Window to Big Window Conversion
The "plug" on the end of the heads is actually a glued on tag that is intended to melt and fall off should the owner overheat his engine following a rebuild. If the tag is off following engine problems, the rebuilder will void the warranty claiming abuse.
Old 07-17-2012, 03:43 PM
Okay, thank you very much. I had never seen anything like this, and this motor is a mystery.
Appreciate the info.
Dennis
Old 07-17-2012, 04:00 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
All i show on that 3858180 casting is that it's a 300 horse 327 from 1964 to 1967 with 2 bolt mains. wish i could help more.
Cole
Old 07-17-2012, 04:02 PM
Cole
Thank you, appreciate that.
Dennis
engine numbers onewinglow Engine 0 03-02-2011 04:20 PM
Engine casting numbers and vin numbers drfo Engine 5 06-18-2010 05:15 PM
Engine numbers D'OnneSmith Engine 1 03-04-2007 11:20 AM
Engine numbers camarodriver Engine 2 09-16-2004 12:47 PM
engine numbers ? andrewcdennis Engine 3 06-03-2002 08:36 PM
