Engine ID tag - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-15-2013, 09:53 AM
ss396si's Avatar
Engine ID tag
I having trouble decoding this: 7. C7f152020
As it appears on the tab obove the timing gear.
The engine is a 454, code:361959
Old 10-15-2013, 10:49 AM
techinspector1's Avatar
Wiki Edits: 326
Big Block Chevy suffix code: Machined pad in front of the passenger side cylinder head or above timing chain cover.
Big Block Chevy codes:
Decoding Big block Chevy engine suffix codes and stamped numbers Q - YZ
Old 10-15-2013, 11:06 AM
ss396si's Avatar
Couldn't find code:C7F, on that website.
Old 10-15-2013, 11:57 AM
RWENUTS's Avatar
You want the other letter and numbers. Like V1010CTX as an example. The ctx is the suffix code.
Old 10-15-2013, 12:22 PM
ss396si's Avatar
Here is whats stamped on the pad:
7. C7f152020
Old 10-15-2013, 02:22 PM
Banned
need the numbers from the back of the motor .where the trans would bolt to.
Old 10-15-2013, 02:36 PM
ss396si's Avatar
#361959, 454 engine.
Old 10-15-2013, 02:58 PM
Wiki Edits: 326
7. C7f152020
Not aware of any site to find that number. Could be a replacement block or a crate motor block.
Old 10-15-2013, 03:02 PM
ss396si's Avatar
Very strange
Old 10-15-2013, 03:46 PM
RWENUTS's Avatar
Not strange!
Block's been decked!
Old 10-15-2013, 04:02 PM
ss396si's Avatar
Originally Posted by RWENUTS View Post
Not strange!
How do you know?
Old 10-15-2013, 04:06 PM
RWENUTS's Avatar
THe letters/numbers you need but can't see are gone.
The ones you do see are obscured and not as bold.
If you clean real good above your numbers and use a magnifying glass you might see what you need.
Old 10-15-2013, 04:20 PM
ss396si's Avatar
If it wasn't for the cranshaft endplay (12-15") I'd put it back together.
1966 Mustang 289 Engine Tag Hugh Freeman Engine 1 03-15-2007 08:42 AM
engine ID tag glessen Engine 4 01-31-2007 11:15 PM
8.8 ford i.d tag 347mustang Transmission - Rearend 4 08-02-2005 10:31 AM
engine tag help stfinney Engine 11 08-02-2003 08:22 PM
9 inch tag mike bryan Transmission - Rearend 2 04-06-2003 06:51 PM
