Engine identification - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-11-2004, 10:59 PM
ChevyTuff's Avatar
Car Audio Junky
I have a SBC 350 that does'nt have numbers stamped on it, but it does have a rivetted badge on it. The numbers read 55181 RC26A. Any help? Thanks.
Old 11-11-2004, 11:23 PM
MI2600's Avatar
Member# 3287
Was it a marine engine?
Old 11-11-2004, 11:26 PM
troy-curt's Avatar
Shop Owner And Troll Hunter
Some rebuilders do that.
Troy
Old 11-12-2004, 09:22 AM
GMC boogie's Avatar
Did you look at the rear of the motor,just below the drivers side head, where the tranny bolts up. Should be a 7 or 8 digit # or possibly 5.7 in raised numbers.
Old 11-13-2004, 04:07 PM
ChevyTuff's Avatar
Car Audio Junky
No, I didn't check there before I installed the engine. Here is a picture of the badge. If that helps.
Old 11-13-2004, 05:04 PM
troy-curt's Avatar
Did you look on the right hand side there is a smooth pad where the head meets the block on front.
That tag was put on by a rebuilder shop.
Troy
Old 11-13-2004, 06:43 PM
Brian Morency's Avatar
Hauling A55 BURNING GASS!!!
Last journal entry: bros car
i thought this motor look familiar
yes look behind the drivers side head just above where the trans bolts up to. maybe get it from underneath or from up top use aluminum foil it worked for me since i couldn't read them number
