Engine Identification - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-03-2006, 09:17 PM
As some of you might know im working on an engine that i was told to be a boss 351 and im trying to identify the block for myself. I guess ford motors have a tag on the front of the engine that tells you what the specs are but this block doesnt have that it mustve been taken off. i do know that because of the number of bolts on the valve covers that it is either a cleveland or a boss but thats about all i know. what else should i be looking at? i know chevy blocks you can call a dealer and give them casting numbers to figure out what the block was, does ford do that as well? thanks for the help
Old 01-03-2006, 10:13 PM
More info
Some numbers i found on the block.
DOAE-L OG27
1F10400
The zeros could be "o's" im not sure.
I found out the intake was replaced with a different one because someone stole the old one...some numbers on the intake
DOAE-9425-L 0G24
18726548
I really need to know what kind of engine this is, its killing me!
Old 01-04-2006, 12:12 AM
onebadmerc's Avatar
I need a bucket of arc sparks
The numbers you posted is not for a 1971 351 Boss Block. The letter D stands for decade which is the 70's, 0 is for the year 70, A stands for type of car which motor is designated for and E stands for engine. The Mustang had a Z code and the Boss 351 was only produced in 71 so the block casting will be a D1ZE-???? number. The next numbers (1F10400) are the machining date, 1 stands for 1971, F stands for month which should be June, 10 stands for date which is June 10 and the 400 I am not sure about. The last set of numbers (18726548) is the firing order.
Old 01-04-2006, 07:14 AM
mstngjoe's Avatar
The D0AE-L should be a standard 2-bolt main, 351C block.
As stated above the Boss 351 would be a D1ZE-B and have 4-bolt mains.
Old 01-04-2006, 08:02 PM
Screw Up
Im sorry i posted the wrong set of numbers from the engine block i did confirm the firing order and i thought that DOAE-L was that too but ive found information that tells 2 different stories. I found one place that said DOAE was a BOSS and another site said it was a cleveland modified or a 400. The correct set of numbers would be as follows:
1F104000
Stupid me i forgot a zero at the end.
crate chevy 302? Vancouver Grand Prix Hotrodders' Lounge 106 12-31-2012 05:05 PM
engine identification snowicki Transmission - Rearend 3 09-04-2003 10:54 AM
engine identification snowicki Engine 8 09-02-2003 04:19 PM
truck engine identification ottscy Engine 0 10-27-2002 03:17 PM
Engine Block Identification carcobias2 Engine 2 10-26-2002 11:08 AM
