engine identification - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-01-2006, 12:07 PM
trying to find out how to determine if a particular motor and transmission on a 1966 ford mustang is original
Old 06-01-2006, 12:21 PM
brainsboy's Avatar
brains
I would guess by the Vin number to find out which S6 or V8 its suppose to have, then Decode the block casting number by the starter, to see if the year matches should start with "C6". If it matches it doesnt mean the heads havent been replaced, so you may want to check those too, just depends how original you want to be.
For the Vin decoding
A= V8 289 CID 4V
C= V8 289 CID 2V
K= V8 289 CID 4V High Performance
T= I6 200 CID 1V
Old 06-01-2006, 01:04 PM
once i have the casting numbers how do i decode these
Old 06-01-2006, 01:14 PM
brainsboy's Avatar
brains
go here
http://www.classicmustang.com/decoding_part_numbers.htm
Engine Identification Guero0123 Engine 1 01-13-2006 02:54 PM
engine identification snowicki Transmission - Rearend 3 09-04-2003 09:54 AM
engine identification snowicki Engine 8 09-02-2003 03:19 PM
truck engine identification ottscy Engine 0 10-27-2002 02:17 PM
Engine Block Identification carcobias2 Engine 2 10-26-2002 10:08 AM
