Engine Identification - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-03-2006, 04:38 PM
I have a 72 chevelle but I cant figure out what motor is in it. where would I find the casting number to identify the motor I found one number [K0714TXB] but I don't think this is the right number to identify what size motor this is
Old 09-03-2006, 06:16 PM
66ImpSS396's Avatar
It's been fun
GM Eng ID
Try the Knowledge Base There is an entire section that will help you.
or Mortec
Old 09-03-2006, 11:29 PM
inquiring_mind2's Avatar
a shade tree mechanic
look on the back of the block by where you would bolt the transmission up. There will be a set of numbers there those numbers will be able to tell you what type of motor you have. Take those numbers and go to www.mortec.com and you can look it up
Old 09-04-2006, 12:00 AM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
The casting number is located on top of the bellhousing flange on the drivers side at the back of the block.
K0714TXB Engine code says it was built in St Catherines, Ontario Canada on July 14, 1975 for C20-3500 series pickups. In stock form it's a 4bbl 350 rated at 165hp. Chances are good that the casting number will be 3970010 or 3970014.
Chevy Engine Codes
Mortec
Engine Identification Guero0123 Engine 1 01-13-2006 02:54 PM
engine identification snowicki Transmission - Rearend 3 09-04-2003 09:54 AM
engine identification snowicki Engine 8 09-02-2003 03:19 PM
truck engine identification ottscy Engine 0 10-27-2002 02:17 PM
Engine Block Identification carcobias2 Engine 2 10-26-2002 10:08 AM
