Engine Idle issues. - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-27-2010, 08:25 AM
Engine Idle issues.
Hey guys. want to pick everyone's brain out there about a small issue I am having with my newly acquired project. I have a 72 Chevy p/u that has a 350 v8 with a Edelbrock carb that was installed on it before I bought it. I don't know a whole lot about carbs other than adjusting the idle speed and a bit about rebuilding them but nothing about adjusting anything else. the truck is running well and drivable so I am pretty sure the mixture is where it needs to be if not close. My issue is the idle speed, when I first picked up the truck from the guy I bought it from it was idling really high, and punching the pedal to get the idle to drop was not working. The carb has an electric choke and now when I start it and run it it goes down to a nice idle speed but it seems that every time I give it gas to go somewhere and then come to a stop it is idling high again and I have to give the throttle a quick punch to get it to go back down to idle and it is fine till I give it gas again and then come to a stop or push the clutch in .
What might be causing this and what do I need to look for next time I am tinkering with it. I am having no problems with the engine running or starting, it fires up pretty quickly. just tired of having to hit the throttle every time I come to a stop . any suggestions?
Old 10-27-2010, 08:47 AM
BlenderHead's Avatar
other people on here will be able to give much better info than I can, but it sounds like it might have something to do with the choke.
Old 10-27-2010, 08:53 AM
adantessr's Avatar
'23 T-Bucket Pickup
Last wiki edit: Troubleshooting ignition Last photo:
Wiki Edits: 3
Start by checking the linkage . It maybe binding or need adjusted to give it a little free pedal .
Old 10-27-2010, 10:40 AM
bubbahotep's Avatar
Check the linkage, check the throttle return spring is tight, possible sticking weights in the dizzy, vacuum leak?
acceleration flat spot in carb. corvettetonybone Engine 17 04-13-2013 08:31 PM
Port or Full time vacuum cool rockin daddy Engine 129 10-05-2010 03:00 PM
Do I need vacuum advance? (Long Post) Chevy21 Engine 49 10-25-2007 12:51 PM
Vacuum adv.. underdog305 Engine 58 01-30-2007 11:19 AM
No ported vaccum port in my Q-jet, help Augusto Engine 11 12-27-2006 05:04 PM
