engine idle speed - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-04-2010, 07:56 PM
engine idle speed
Hi,
My 1986 astro van idles to fast,and when I go into drive
or reverse it puts to much torque making a clunking sound.
I thought I had something wrong with transmission But
The transmission man said it was OK.
The manual says there is no adjustment for the idle.
Its not real real bad but I don't like putting so much
strain on the drive train, Any advice appreciated.
Thanks, gene
Old 07-07-2010, 09:03 PM
milner's Avatar
high idle
check for vacume leak, or a leaking throttle body gasket, these will make it idle faster than normal. there is a idle adjustment, but it factory set and should not be changed. check for leaks with brake klean, with engine running. if there is a leak, you will hear the RPMs change. hope this helps.
acceleration flat spot in carb. corvettetonybone Engine 17 04-13-2013 08:31 PM
Pinging on 03 Chevy 5.3 Engine in Suburban bry21317 Engine 42 10-02-2011 07:35 PM
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 12:38 AM
No ported vaccum port in my Q-jet, help Augusto Engine 11 12-27-2006 05:04 PM
engine idle loping heavy evy Introduce Yourself 1 09-16-2004 12:40 PM
