engine idleing funny - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-16-2006, 11:53 AM
freshly rebuilt 350 idles down when idling. it will set and idle at higher rpms but at lower rpms it justidles down till it dies. and misses a little bit but not like a plug or misfire. i'm thinking a vacuum leak but not for sure.
Old 05-17-2006, 05:16 PM
Old Yeller 1970's Avatar
Loud Pipes Save Lives
What kind of condition is your carb in? New? Used? Manufactured by -----?
And what kind of rebuild? Stock cam? Street Performance?
Old 05-17-2006, 05:27 PM
Its A Older Elderbrock 1406. The Build Is A Little Radical Everything Was Balanced On The Bottom End. It Has A 500 Lift Cam And 12 To 1 Compression. I Think Mostly Vacuum But Not For Sure. Thanks.
Old 05-17-2006, 07:35 PM
Has it been doing this ever since the rebuild?
Old 05-17-2006, 07:48 PM
no it happened after i readjusted valves one valve was a little tight solved everything. i appreciate everything after you asked about the setup i remembered i readjusted a loose valve
Old 05-17-2006, 07:55 PM
In that case I'd have to agree that it's probably a vacuum tube causing your trouble.
ENGINE BALANCING NAIRB Engine 22 01-23-2016 01:44 PM
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 06:57 PM
1973 Chevelle Malibu Engine Rebuild (pics 56k no) Malibu73 Hotrodders' Lounge 39 11-04-2008 12:37 PM
Build for Hp or Torque? Venturat Engine 76 09-23-2008 10:22 AM
question for any engine builders out there mopar72 Engine 7 11-06-2005 03:06 PM
