engine indentification - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-14-2003, 11:51 PM
I have a motor out of a 1970 chevy truck: however, it is not the orginal and I am trying to indentify the motor. The block cast number is 3970010, piston # is 6271096, front of block is V0803 CUB, the head # is 333882.The motor appears to have been casted in 1976. I beleive the motor came out of a car and is a 1976 nodel.
Old 12-15-2003, 08:39 AM
M&M CUSTOM's Avatar
Wiki Edits: 9
3970010....302.....69....4...Z-28 Camaro
3970010....327.....69....2...Trucks and industrial
3970010....350...69-80...2 or 4
cast# years CID HP rating carb application
3970010 1969-79 350 185 or 370 2 or 4 car, truck, Vette
V0803 CUB
V= Flint, Michigan engine plant
0803=August, 03
CUB=
Year RPO CID application VIN HP Carb Body/Comments
1975 CUB 350 4 spd trans. J L48 165 4bbl Vette
1977 CUB 350 LM1 L 170 4bbl B
1980 CUB 305 LG4 H 155 4bbl B
333882.....74-80...350/400......76cc chambers
6271096 crosses over to this information found for Silvolite piston number 1470
This information was found at:
http://www.beckracing.com/slvpg29.htm
