engine 'just cranked for first time' - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-30-2002, 07:46 AM
Post engine 'just cranked for first time'
Seems too idle too fast i.e. about 950-1050 with idle adjustment completely off the adjustment arm [no more 'less rpm adj' there]
Have high rise and big Q-jet on 327 chevy. Have checked all vacuum and no leak is there ...maybe timing is too advanced but I am thinking jets are too big for the 327.
Any ideas or suggestions? Summitt thought maybe a leak 'under the manifold'
Old 10-30-2002, 11:17 AM
slider in wa's Avatar
Slider in Wa.
Post
Turn the timing back until it will run and then with it at operating temp. set timing, and carb.
Slider in Wa.
Old 10-30-2002, 11:36 AM
bullheimer's Avatar
NEVER use credit cards!
Post
yeah, if you cant get it to drop by moving the distributor you just gotta have a vac.leak. unless your float bowls need adjusting. any gas coming out the top of the carb into it?
Old 10-30-2002, 06:42 PM
MI2600's Avatar
Member# 3287
Post
You might check to make sure the linkage isn't holding the carb off idle.
Old 10-30-2002, 07:22 PM
Last journal entry: Doors
Post
MY engine also idles at around 1000 RPM, i just started it up and havent moved the car under power since the eingine was installed, wiht mine a traced it down to the choke
Old 11-02-2002, 07:09 AM
Post
Thanks good suggestions...I also believe the timing is the correct answer as soon as I can get to the car [we are under much snow] I will take that apprach.
Old 11-02-2002, 08:33 AM
Post
I have had this happen to me twice with two different carburators. Both times it was parts on the oposite side of the throttle cable that stopped the throttle plates from closing all the way. It took me a while to figure it out but after a small adjustment, everything worked right.
