Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Engine just dies
Old 04-29-2005, 10:45 AM
SmallBlock_guy's Avatar
SmallBlock_guy SmallBlock_guy is offline
Engine just stops??
What do you mean the engine just stops. Give me more details. Does it try to stay alive or below 850 and gone!
By changine the rocker ratios you may need to play with the idle fuel. Also look at the MAP readings are they the same with the new set up??
