Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - engine keeps shutting off
Old 05-31-2009, 02:49 PM
eloc431962's Avatar
eloc431962 eloc431962 is offline
Evil Wicked Mean And Nasty
Wiki Edits: 37
Originally Posted by cobalt327
It sounds as though it's not running on the idle circuit at all. Is the carb in good condition? Floats not too low?
Depending on what the carb is set like, you may need to richen up the idle screws and then compensate by lowering the curb idle screw until you get a good idle.
Thats what i was thinking too Colbalt. I think the floats are way out (TOO LOW)had this problem not to long ago with a 68 chevelle i had. same symptons floats were adjusted all the way down they had them down so tight i had to take it apart so to adjust them properly. The guy i got it from said it was fine a new one. Later i found out his son had been adjusting on it and could not get it right hmm go figure. What carb do you have? Cole
