engine knock - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-02-2012, 05:04 PM
engine knock
How do I stop a light engine knock?
Old 02-02-2012, 05:13 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Welcome to the board
The first thing you need to do is identify it, is it in the valve train, bottom end, only at idle, what events led up to the knock?
Has your oil pressure dropped at idle, at normal operating rpm?
If it's in the bottom end, I would assume a bad rod bearing, or possibly a main, and you should see a decrease in oil pressure.
Semper Fi
Old 02-04-2012, 12:47 AM
vncruiser's Avatar
Gearhead
If it is in the bottom end, the first thing to check is the torque convertor bolts (assuming it has an automatic transmission). If the bolts are tight, you most likely have a bad rod bearing...
Reid
Old 02-04-2012, 09:57 AM
techinspector1's Avatar
Wiki Edits: 326
An exhaust leak at the header or a cracked flexplate can sound just like something going south in the motor.
Old 02-04-2012, 10:04 AM
adantessr's Avatar
'23 T-Bucket Pickup
Last wiki edit: Troubleshooting ignition Last photo:
Wiki Edits: 3
You can tell if the knock is deep like wrist pin, cracked piston or a rod bearing by pulling plug wires, one at a time. If it changes in sound, be prepared to tear the engine down. Not enough info, so far, to tell you anything else.
Old 02-04-2012, 11:31 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Are you talking about "spark knock" or ping? Or a mechanically-related engine knock?
Engine Knock moneymanshawty Engine 3 04-10-2010 09:20 AM
engine knock ikeaguirre14 Engine 3 02-06-2005 06:41 PM
bad engine knock bry74ta Introduce Yourself 1 01-16-2005 12:57 PM
Help!!! Knock, Knock, Knock coming from tranny 70bird Transmission - Rearend 1 05-06-2004 12:30 AM
engine knock reborn55 Engine 4 02-11-2004 02:46 PM
