Engine leveling que. - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-01-2004, 05:48 PM
Hey guys, my motor is installed with trans and my carb is all set, now when I put a level across the top of my butterfly my motor leans back towards the rear about a good 1/2 inch, is this going to be o.k.? Dana
Old 03-01-2004, 05:55 PM
BOBCRMAN@aol.com's Avatar
That is fine. Most installations require the front to be higher than the rear. 1/2" is in the ballpark
Old 03-02-2004, 03:48 AM
Frisco's Avatar
Glad To Be Here
Re: Engine leveling que.
If I am reading your post correctly, the carb is level and the engine is tilted down at the rear. If this is the case that is 'normal' and will work fine. The carb mount on the intake manifold has a 3-4 degree forward angle built into it. When leveling the engine, place the level on the carb mount portion of the intake. Level everything from that point both front to rear and side to side. The object is to have the carb level, not the engine.
Old 03-02-2004, 06:04 AM
TurboS10's Avatar
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
Good advise frisco. Make sure that the tilt is not on the carb mating surface it should be level or damn close.
Chris
Old 03-03-2004, 05:52 PM
thanks for the info, Dana
