engine lifters are making a ticking noise - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 12-23-2010, 03:32 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Originally Posted by American Muscle
Header leak brother. I had the same problem before so I swithched to these original manifold gaskets. Not a leak ever again and so easy to install
http://www.napaonline.com/Search/Det...+50014+2014024
I have alway's had best luck with the Original gaskets also.
Somthing like these.
http://www.summitracing.com/parts/FE...FQEGbAodomcFoA
Cole
  #17 (permalink)
Old 12-23-2010, 03:41 PM
muddi1's Avatar
Does anyone know if they make a square/rectangle flanged header for a BBC? I would certainly and gladly change mine, I have just not done any research and the two sets I picked up were "the right price".
These are the stock GM 336781 heads that have the intakes and bowls ported and polished.
  #18 (permalink)
Old 12-23-2010, 03:57 PM
King of my Man-cave.
Hmm, 9 months for this thread.....................
Comp has had serious lifter problems in the last couple of years, mainly with their hydraulic roller pieces. It's entirely possible you have a bad lifter.
Or cam going flat.
tom
  #19 (permalink)
Old 12-23-2010, 05:07 PM
muddi1's Avatar
Well, even if it turns out not to be a header leak, I have found square header flanges for many applications including your SBC and my BBC.
Victory Header Flanges, makes most any configuration imaginable, and for a BBC square set $65 is not a bad deal at all.
acceleration flat spot in carb. corvettetonybone Engine 17 04-13-2013 09:31 PM
Knowledge base Dave57210 Hotrodders Site Suggestions and Help 2 12-20-2009 08:06 PM
pontiac 400 low oil pressure, engine noise Blob Engine 3 08-12-2006 10:11 PM
I need engine noise help!!! 1931 steve Engine 7 07-28-2006 08:09 AM
Engine valvetrain tap sy733 Engine 19 12-17-2005 01:09 PM
