engine lifters are making a ticking noise - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-27-2010, 06:23 PM
watchdude1's Avatar
I have a 350 8.5 -9 compression engine I purchased 6/09 a comp cam and lifters hydraulic 218 218 .454 .454 lift .50 duration , comp roller rockers 1.5,Edelbrock E street aluminum heads 64cc or 70 cc I adjusted the lifters as comp cam said tdc do exhaust and intake, it sounded ok but still had a ticking sound, it sounds like all lifters are ticking, so I adjusted the lifters by warming up the engine loosen the rocker nut until it started making noise then tighten until it stopped and then gave 1/4 turn more. did all 16 but now when I run the engine it just doesn't sound wright, it has a ticking sound to it don't know why it is like this? I have a video on utube you can hear the engine in the video.
.http://www.youtube.com/?v=pbbRQm-JIPY
thanks for any info you can give me
Old 03-28-2010, 12:09 AM
Ticking Sound
Hello does it make that noise with valve covers off? I've have rockers just barely hit the valve covers after I installed a cam and lifters, bigger springs, etc.
Hope it helps.
Old 03-30-2010, 04:57 PM
watchdude1's Avatar
The roller rockers are the stock type 1.5 they might be hitting I will have to listen to the valve covers dont want to take them off right now they might start leaking , Called Comp Cams this is what they said, anyone ever hear that Comp cams have a ticking sound to them??
All of our profiles have a loud tick to them, which is one of the things that helps us get the power we get. The profiles are aggressive, so they have a ticking sound and when you put roller rockers on top of them that will intensify the sound. If it is more on one or two lifters, there could be a problem, but if it is uniform on all cylinders, that is just the way itis going to be. The pushrod length normally won't make it tick, but you should check for proper roller contact on the tip of the valve.
Old 12-21-2010, 06:09 PM
watchdude1's Avatar
HI' I removed the valve covers and re adjusted the lifters warmed up the engine Let off the nut until they got nosy then tighten down until noise stopped then 1/2 turn to all lifters the left side is still ticking, maybe one of the lifters is bad sounds like the one in the back on passenger side they are new lifters maybe not enough ol at start up on the lifter?.
Here is my last video I am going to sell the car if I cant fix the problem
http://www.youtube.com/watch?v=-7zvtrlmdTE
Old 12-22-2010, 04:20 PM
muddi1's Avatar
I may be way off base here but maybe not, when I put my engine together and after the cam break-in I had the same "type of noise" I thought it was a lifter so I went through the whole lifter noise hunt.
For the life of me I couldn't figure it out, with the engine on my test/run stand and standing on the passenger side I leaned over to check the gauges....I felt a little hot "putt-putt" on my knee, so I investigated....my header had the smallest leak I have seen. I went through again and heated/cooled the engine a few times tightening and re-tightening the header....no more "putt-putt" or "lifter tap"
Maybe?
Old 12-22-2010, 04:51 PM
techinspector1's Avatar
Wiki Edits: 326
I can almost guarantee that is a header leak. I can hear it going fssst, fssst, fssst in the video.
Old 12-22-2010, 05:36 PM
watchdude1's Avatar
Maybe?
Thanks I tighten all the header bolts and re checked them there tight< I will check them again, the Edelbrock heads have square outlet ports for the exhaust my hedders are for a round exhaust port could that be the problem even though there are gaskets on them? my old heads were stock round exhaust ports. after buying new cam,heads didn't feel like spending more cash for new hedders
Old 12-22-2010, 05:40 PM
Wiki Edits: 326
Thanks I tigten all the header bolts and re checked them there tight<
If they are the cheapo thin flanges and are warped, you can tighten 'til the cows come home and you'll still have a leak. Been there, done that.
Old 12-22-2010, 06:17 PM
I've had really good luck with MrGasketCo's compressed aluminum gaskets (look like layered tinfoil) and my headers... both with not leaking, and with the bolts not loosening up.. and on the rare occasion a bolt does loosen up, the gasket doesn't immediately burn up and blow out
Old 12-22-2010, 06:26 PM
ericnova72's Avatar
More for Less Racer
Sounds like a header leak to me also. Usually once it leaks, no amount of tightening will fix it, it's burnt, time for a new gasket.
Old 12-22-2010, 06:31 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Cole
Old 12-22-2010, 07:21 PM
001mustang's Avatar
Detecting header leaks
How does one find small header leaks?
Carbon stains, puffing and ???
Old 12-23-2010, 12:38 AM
muddi1's Avatar
My headers are of the round type and square ports on the heads. After doing some reading here I made my own "adapter" gasket out of a sheet of 3/16 aluminum. (An old out of commission road sign works well)
I bought a set of stock exhaust manifold gaskets and compared them to the heads and the headers, the gaskets didn't match up to either one. I traced the gasket onto the sheet and cut it out with my make shift band saw (my horizontal with a larger plate bolted to the "stop" plate) I found a hole saw that was the same size as my headers and drilled the centers out. I had to "notch" my header flanges to just miss the new ARP head bolts, that is why the funny "dip" is in the aluminum gasket.
After that I cut both the gasket and the "aluminum adapter" into eight individual gaskets. I also used the ever so popular High Temp Gasket Maker/Sealer between the aluminum gasket and the header (Not sure it was needed?). It took all of two hours to complete the whole job. Even with the slight restriction in the corners they will breath way better that the cast iron stock jobbers.
Even with square exhaust ports and round headers they seal up very nicely!!
Here are some pictures of some I am "doing up" for my next 454 build.
ID:	51039   Click image for larger version
Name:	header gasket 2 002.JPG
ID:	51042   Click image for larger version
Name:	header gasket 2 003.JPG
Old 12-23-2010, 01:26 AM
American Muscle's Avatar
305 Turbo-Fire 240hp
Header leak brother. I had the same problem before so I swithched to these original manifold gaskets. Not a leak ever again and so easy to install
http://www.napaonline.com/Search/Det...+50014+2014024
Old 12-23-2010, 02:51 AM
jeeeze, that makes me glad my header tubes were bigger then my exhaust ports!! I just bolted the gasket to the head, marked, and worked the ports open to match the header tubes...
acceleration flat spot in carb. corvettetonybone Engine 17 04-13-2013 08:31 PM
Knowledge base Dave57210 Hotrodders Site Suggestions and Help 2 12-20-2009 07:06 PM
pontiac 400 low oil pressure, engine noise Blob Engine 3 08-12-2006 09:11 PM
I need engine noise help!!! 1931 steve Engine 7 07-28-2006 07:09 AM
Engine valvetrain tap sy733 Engine 19 12-17-2005 12:09 PM
