Engine lifting plates - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 02-06-2008, 06:15 AM
schnitz's Avatar
Last wiki edit: Building a new shop
Last journal entry: Christmas 2008 came early!!!
Wiki Edits: 54
Originally Posted by 302 Z28
Me also, but they were 3/8" bolts into the heads. Don't know if I would trust 2 5/16" bolts into the carb mounting flange .
Vince
...Which is why I questioned you guys. I'm thinking I'll just use the factory lift brackets and the 5/16" chain I've always used. However, the next time I run across the need to pull a sbc with a 2 barrel (that is junk to start with...), I'll try it with a plate just to see if it'll handle it.
In a while, Chet.
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 06:57 PM
Valve Lash adjustment hiball Engine 36 05-11-2009 10:12 AM
Build for Hp or Torque? Venturat Engine 76 09-23-2008 10:22 AM
1985 C-6 truck tranny, no engine braking effect fast68 Transmission - Rearend 40 02-04-2008 05:55 PM
question about c4 friction plates desman Transmission - Rearend 2 06-07-2006 07:39 PM
