Engine lifting plates - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-04-2008, 08:41 PM
57halfton's Avatar
Anyone use those lifting plates that bolt to your intake manifold where the carb bolts on for lifting your engines ? Do ya' trust those four 1/4 inch studs in an aluminum intake ?
Gene
Old 02-04-2008, 08:48 PM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
I use them on my 454
The bolts must be tight, and not bottom into the manifold.
On a Chevy the bolts are 5/16, so the bolts that you use must thread into the MANIFOLD at LEAST 3/8"------1/2" is better.
Old 02-04-2008, 08:52 PM
57halfton's Avatar
OOP'S your right , they are 5/16 , Thanks , Gene
Old 02-04-2008, 09:51 PM
Last journal entry: Journal Update
RE:Engine lifting plates
I used one to pull and re-install a big block Chevy in my El Camino. Flawless. Make sure the bolts are long enough. If I recall, I was told once that a 1/4-20 bolt has a tensile strength of over 1000 lbs. This was from a mechanical engineer. And I remember that I thought he was crazy, till he showed me the proof of a grade 5 bolt, I was floored. I found a webpage that has a really handy list of this information as well as torque info. It's here: http://www.derose.net/steve/resource...les/bolts.html
Here is a photo of the engine it was dropped in as you see it WITH the turbo 400 transmission attached to it. All in one shot.
Old 02-04-2008, 10:09 PM
powerrodsmike's Avatar
Wiki Edits: 161
There was a thread like this a while back..fun one too.
Lifting a motor by the intake
Later, mikey
BE different....ACT normal.
Old 02-04-2008, 10:28 PM
Lifting Plates
Tools work when correctly used. There is always a horror story somewhere! Personally, the force on the plate is tensile strength. When using a chain that has a bolt through it and lifting on a 45 or a 90deg angle, (such as a bolt on the front and back of the block or the intake bolts on corners) you are now using shear strength which is much less than tensile strength. (not saying any way is right or wrong, just my observations) I used the lifting plate that's on the motor and a leveler to tilt the engine as needed. Never had a problem. If you like using the chain and intake/block bolt method, it works too (I have done it a bunch of times) Just be safe! If the threads on the intake were iffy, I would have not used the lifting plate. But I managed to put the motor as pictured with the trans, torque converter all attached in to the vehicle, and without incident.
Old 02-04-2008, 10:57 PM
Wiki Edits: 161
I only pointed out that thread to show what others here have said before, and to show that a search of the site is a good way to start when a guy has a question...
I have an engine lifting plate, (2 actually), and I have one of those hand cranking balance bar things..
I use them both as well as regular old chains ..
Ine time I dropped a 5.0 with a T-5 behind it while using a chain with 2 5/16" bolts in the intake side of the heads. It came down on the end of the trans and then the block fell on the cowl of a sunbeam alpine.
I replaced the bolts with grade 8 in the same holes and picked it up again.
Then I did bodywork..
Crap happens. .
Later, mikey
Old 02-04-2008, 11:09 PM
re: Engine lifting plates
I couldn't agree more with you. We all learn from our mistakes. Just gotta be safe. That's what it's all about. If you don't think it's safe, then dont.
Old 02-05-2008, 04:44 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
I have been using a lifting plate for years...I like them a lot better than the other way.
Old 02-05-2008, 05:15 PM
schnitz's Avatar
Last wiki edit: Building a new shop
Last journal entry: Christmas 2008 came early!!!
Wiki Edits: 54
O.K. But would you guys trust using a lift plate when you only have 2 holes to bolt to? Remember, I have a 2 bbl. carb on my 305...
In a while, Chet.
Crap happens. .
Later, mikey
How much would you have to recess the firewall to fit a jag v12 in one of those lil Brittish cars?
Thanks
Shane
Old 02-05-2008, 05:23 PM
Lost in the 60's
Wiki Edits: 4
In a while, Chet.
Yes if you have a plate made for two holes...I think it would be all right. When we used to pull them with a chain , we only used two holes. A lot of two barrel carbs have 4 bolt holes though....even the old Rochesters on my tri-power set up ....they have four bolts
57halfton's Avatar
Thanks guys , I think i'll try a lifting plate.
Gene
Old 02-05-2008, 08:05 PM
techinspector1's Avatar
Wiki Edits: 326
I've made 'em in tne past from scrap steel plate and a u-bolt from a muffler hanger.
Old 02-06-2008, 05:55 AM
302 Z28's Avatar
Me also, but they were 3/8" bolts into the heads. Don't know if I would trust 2 5/16" bolts into the carb mounting flange .
Vince
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 06:57 PM
Valve Lash adjustment hiball Engine 36 05-11-2009 10:12 AM
Build for Hp or Torque? Venturat Engine 76 09-23-2008 10:22 AM
1985 C-6 truck tranny, no engine braking effect fast68 Transmission - Rearend 40 02-04-2008 05:55 PM
question about c4 friction plates desman Transmission - Rearend 2 06-07-2006 07:39 PM
