Engine lopes in Gear - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-19-2006, 05:20 AM
budthespud's Avatar
Diehard Chevy Guy
My 74 Firebird with the 400cu engine has a problem when it's in gear. When you put it in gear the engine revs up and down from 550 rpm to 800 rpm. Now I've played with the timing, adjusted the idle screws and checked for vac leaks with no change. The motor has a 4bbl, mild crane cam, and headers/flowmasters which keeps it a relatively stock engine. Any help on this would be greatly appreciated.
Old 04-19-2006, 07:10 AM
tnsmith10's Avatar
when will it rain???
how long has it been doing this? have u made any changes to the car since u noticed this problem?
Old 04-19-2006, 01:01 PM
techinspector1's Avatar
Wiki Edits: 326
Have you checked fuel pressure at the carb inlet? Should be 6 psi max. Just a thought, but it might be dumping raw fuel in and causing the motor to cycle.
Old 04-19-2006, 01:58 PM
Is your AC or defroster turned on? Perhaps the compressor is cycling, and the idle solenoid is whacked.
Pat
Old 04-20-2006, 06:17 AM
Technical Support Barry Grant
If you've already checked for vacuum leaks, and you it's not a compressor problem. You're dealing with either fuel or ignition. It should be somewhat easy to diagnoise what the engine wants at that point.
Put some wheel chocks in front of your front tires, and have someone sit in the car WITH THEIR FOOT ON THE BRAKE now when the engine is surging up and down press on the accelerator pump of your carburetor without moving the throttle linkage. This will add fuel without changing the volume of air that goes through the carburetor, and let you know if you're running too rich or too lean causing this problem.
Old 04-21-2006, 05:04 AM
budthespud's Avatar
Diehard Chevy Guy
Well there is no AC in this car so that's not the problem. The car has an electric fuel pump that might be giving it too much fuel pressure? Maybe a pressure regulator should be installed. It was doing this a bit before but now that I've made some timing changes it's more evident. I'm still thinking it's a fuel problem more than a ignition problem. Well I can't do much for the next few days got other things on the go but I will get back on this and let you all know what happened. Thanks
Valve Lash adjustment hiball Engine 36 05-11-2009 10:12 AM
7 hours, 33 phone calls, &30 pages of Threads later... Rearend? Tranny? Need Guidance 68ChevelleFromHell Suspension - Brakes - Steering 19 01-13-2006 01:01 PM
Rebuilt Engine Squeaking, Driving me Nuts! BH69Camaro Engine 24 04-22-2005 08:51 PM
Cam Help black66 Engine 3 05-12-2003 06:15 PM
the best engine parts, chain vs. gear, engine combos jollygiant_57 Engine 6 05-01-2002 09:34 AM
