Engine Machining Process - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-11-2004, 06:49 PM
new learner's Avatar
Could someone explain the engine block machining process to me so that I will not sound completely stupid when I walk into the local machine shop?
Old 05-11-2004, 07:17 PM
HemmiGremmie's Avatar
Last journal entry: 52 truck
Hello.
I just had mine done.
You will probably want the block hot tanked and washed so its nice and clean. If the cylinders are bad you will want them bored out. Usually 030 thousandths, but it depends on if it was bored before or if its in need of more than 030. Have the block checked to see it needs decked. That is so the top of the motor is straight and square.
Have them put new freeze plugs in it and install new cam bearings.
Mine cost 318 bucks. Its pretty cheap around here to have machining done. HG
Old 05-11-2004, 07:23 PM
Thanks for the info. All info is good info when learning. I will be having a 350 done.
Old 05-13-2004, 09:52 PM
Bad Rat 414's Avatar
www.bigblock67chevelle.com
You might want to have the main caps line honed ot checked to make sure they are straight.
Old 05-14-2004, 05:17 AM
ChevelleSS_LS6's Avatar
Jeep XJ and a Javelin
Last wiki edit: Compression test
Last journal entry: August 9, part III
Wiki Edits: 7
oven cleaner works as a good hot-tank in a can. I got that from a Car Craft magazine.
Old 05-14-2004, 07:37 AM
CurtisL's Avatar
Automotive tech.
dont forget to take your heads with you .. you would probably like to get them ported and polished.. that would make any man smile..
Old 05-17-2004, 12:29 PM
bullheimer's Avatar
NEVER use credit cards!
first thing is you need to know that your' gonna be droppin about two hundred dollars maybe three if your crank needs turning. so you should see if they take cash check or credit card
Old 05-21-2004, 07:42 AM
Hey,
One thing you don't want to do is walk in and start talking like you're the expert while actually you are only repeating some terms you heard on the forum
Best be honest and tell them you are not so experienced, ask their advice. Do shop around though, some may try to take advantage of you.
But the worst thing you can do is start talking like you're the expert - sooner or later you will make a mistake and look WAY more stupid than you would admitting you are inexperienced.
Old 05-21-2004, 02:18 PM
King of my Man-cave.
Yeah, we LOVE it when guys do that. They get our SPECIAL attention!
tom
Old 05-21-2004, 02:34 PM
Tim240Z's Avatar
Do yourself a huge favor and go to the book store, or library and get a book on rebuilding engines....knowledge is king:
Or leaf through your summit racing catalog....yoou do have a summit racing catalog, right?
