Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Engine Masters Critique my 383 SBC Build
  #19 (permalink)
Old 11-11-2008, 12:36 AM
973kgt 973kgt is offline
Ok, here's some changes in considering. NOTE: ** denotes a change.
1987 caprice, 200-4R tranny, .500 boost valve, billet servo, 5500rpm shift governor. Right now it has a 9" 3000 stall converter(custom built Edge racing converters). It is a lockup converter, Tranny cooler. 3.90 posi rear end. Approx 4000lbs including driver (gathering parts to swap to a T-56 6speed trans)
**-Gen I SBC, 4-bolt splayed mains, 1 piece rear main seal, OE-Roller block, 0.030" Bore, "0" deck.
**-Canfield Aluminum 195cc, 65cc CNC chamber, 2.055/1.60 or considering AFR 195cc Eliminators with 65cc chambers.
-1.6 Ratio Aluminum roller rockers
**-0.039" thick Felpro Permatorque MLS head gasket 4.166" bore
-Scat cast steel 383 stroker crank. 3.750 stroke
-5.7" forged I-beam rods
**-SRP Forged flat top pistons, -5cc dome, 1.285 compression height, approx 10.89 static compression ratio, 8.42 dynamic compression ratio, 445 grams
-Balanced rotating assembly (Internal balance)
-Comp Magnum Hyd Roller 286HR cam, 230/230 dur@50, .596/.596 lift with 1.6 rocker. 110LSA, 106 intake centerline, approx power range 2500-6000.
-Edelbrock performer RPM Q-jet manifold with 3/4" 4 hole spacer. (dual plane intake) 1500-6500rpm range.
-Cliffs Performance built Q-jet 780cfm, 1/8" Heat insulating gaskets used above and below carb spacer creates 1" total spacer height.
-1 3/4 ceramic coated headers (long tube)
-2.5" inlet/outlet 2-chamber Flowmasters
-2.5" Dual exhaust with X-pipe
-Spectre performance Dual cold air intake (carb hat with two 4" air inlets, draws cool air from front of car and traps hot air out of intake.
-Water pump fan delete. Electric fans on 4 core radiator.
-Standard flow oil pump with Milodon 7 Quart oil pan and windage tray.
-Double Roller timing set with 2 piece timing cover for easy cam swaps.
-FBO systems Built HEI distributor with MSD 6-AL ignition box (multi-spark) with 6250rpm rev limiter chip.
-Oil cooler with filter relocation kit (Dual large filters) Makes it about a 9 quart oil system.
Considering the XR288HR cam part number 08-433-8
236/242 @ 50
.555/.576 lift with 1.6 rockers
110 lobe sep
106 centerline
I might have to drop the compression a hair to use this without pinging. Tell me what you think about the cams. Suggest something else? I want to hear. Should I advance the cam a little? Remember this is an all street car that weighs 4000lbs. I would like a decent sounding cam but im more concerned with function. I've thought about going with a 106 lobe sep but i think id have to lower compression more. Im open to ideas.
