We're winning the case!
Hotrodders Bulletin Board > Tech Help > Engine
  #16
Old 07-05-2009, 12:27 PM
tuneup427 tuneup427 is offline
cj, read the number in my post. It is .001 and .002. You won't get a rod knock out of that amount of excess clearance. Just so you know a typical sheet of paper is .003. What you need to realize is there are varying degrees of "excess clearance". That is why the use of terms like slop is sloppy. I would agree that something like .005 or more will give rod knock and if you try to run it hard, catastophic failure. (spun rod bearing and real rod knock.) It still stands --Excessive bearing clearance causes oil consumption from the oil rings being overwhelmed with oil! Not pistons being jerked around.
Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "Engine Mechanics! Help with Oil problems please!"
1968-1969 olds 455 engine is this good and how can i id 1968olds455HO Engine 5 09-02-2009 11:53 AM
Oil leak rear of engine - why? and reuse intake gaskets? sabino56 Engine 12 12-02-2007 01:33 PM
pontiac 400 low oil pressure, engine noise Blob Engine 3 08-12-2006 09:11 PM
Engine oil cooler questions??? Blown72Camaro Engine 11 05-12-2004 09:16 AM
Should I change my oil? 48Man Engine 2 01-29-2003 07:28 AM
