Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - engine miss
Thread: engine miss
Old 11-16-2012, 08:52 PM
cdminter59 cdminter59 is offline
engine miss
You can use a multi-meter or ohm meter to check spark plug wires. Hold a lead to each end of the wire, set the switch to ohms. If the wire is good the reading will be 0. The distributor that Skip White sells is made by ProComp. Do a search on this site on ProComp distributors. Their products are not very good quality. Read this article on Hei distributors. http://www.crankshaftcoalition.com/w...EI_distributor
