engine miss firing - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-27-2011, 12:10 PM
engine miss firing
im running a Chevy 385 fast burn engine , starts good runs good but if you hit it to the floor it will break up ,let off and hit it again and it will go,
Old 03-27-2011, 12:42 PM
Shaker455's Avatar
Okay how about some specs:?
Carb
Jetting
Dist & how it's timmed
Intake & exhaust
Old 03-27-2011, 01:30 PM
bondo's Avatar
Ayuh,... Sounds like it's goin' Lean,...
Richen the acceleration circuit...
Old 03-27-2011, 01:57 PM
snkbyt's Avatar
ASE Master
Last journal entry: 52 Chevy for sale
Yep...Bondo, I agree. Sounds like running out of fuel. My first thought was a flat cam til you said it comes back...letting up on the throttle lets the carb refill. Low float, weak pump, collapsed fuel line, tank screen plugged, plugged filter.
Old 03-27-2011, 02:22 PM
Last journal entry: Some More Roll Cage Fabrication
Sounds like a weak/bad ignition coil or a fault with the ignition system like a tach wire shorting out. Good Luck.
Old 03-27-2011, 04:00 PM
engine miss firing
the engine has a holley 780 on it can you tell me how high the fuel should be in the glasses
Miss-Firing HEI 70bird Engine 6 10-20-2008 08:14 PM
Please HELP 98 Vortec engine miss Rescurat Engine 17 06-01-2006 04:39 AM
Miss Firing Chevy FoMoCo62 Engine 7 12-05-2002 02:59 AM
350 engine miss joefromcocomo Engine 6 09-05-2002 11:08 AM
Engine miss Nitro Engine 4 08-04-2002 04:33 AM
