Engine is missing, help! - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-19-2010, 09:06 PM
Hey, my 355 chevy sb has been running odd for the past week or so but with the 268/280 cam in it, I've just thought it's been me. It has been almost sounding like it was missing but I couldn't tell. But today I replace the stock manifolds with some long tubes. Fired right up but the engines rough running was more noticeable and cut off soon after. I don't know what came over me but I touched the headers for some reason and lo and behold only 6 of the header pipes were hot. the back 2 cylinders were cold as they first were when I started up the engine, cold to the touch. So I looked at my old manifolds and they were like I thought, moist on the inside of the chamber. So, Cylinders 7 & 8 (I think that's right) are not firing at all. Can anyone help me with this dilemma???
Old 05-19-2010, 09:32 PM
DoubleVision's Avatar
Find out why your not getting anything out of those 2 cylinders. Yank the plugs and see if they are fouled. If they check out okay the next step is compression test. Check the distributor cap and plug wires and make sure they check out okay. It could be many things causing this, one is burned valves, blown head gaskets (not very likely on both banks) Rocker arms out of adjustment, leaking intake gaskets, broken rings or piston. Just go over all the checks and you`ll find the issue. The last time I delt with something like this where it fouled both the 7 and 8 spark plugs my intake gaskets were leaking on those 2 cylinders causing it to oil foul the spark plugs.
Old 05-20-2010, 09:27 AM
I have new intake seals, and new spark plugs. The engine was rebuilt about a year and a half ago so i think the valves would be be fine (but I could be wrong) Pistons came with the kit as well as the rings. I'll check the wires but how would I go about checking the distributor and doing a compression test?
Old 05-20-2010, 09:55 AM
ChevelleSS_LS6's Avatar
Jeep XJ and a Javelin
Last wiki edit: Compression test
Last journal entry: August 9, part III
Wiki Edits: 7
purchase a compression tester. Disconnect ignition (and preferably fuel as well). Hook up compression tester (in a spark plug hole) and hold throttle wide open. Crank engine over. See what the psi reading is. Move to the next cylinder. Repeat. It is important to have the throttle wide open. With the throttle closed the readings will be lower.
Some guys use the 'finger test'. If there's enough compression to push you finger off, it'll be ok. I use this for small mower engines, but guys have done this for a long time to find a good junkyard engine.
Old 05-20-2010, 10:34 AM
It doesn`t matter that the engine is close to new, things go wrong. If it had over 100,000 miles on it I`d tell you to do the same thing. I wish after I did a rebuild that I never had to lay a wrench on it again but I will sooner or later, that`s just how automotive is. The intake gaskets are new, that don`t mean it sealed up. I installed 2 pairs of fel pro gaskets on my Vortec 350 years ago and neither pair sealed up. I took the carb off and oil was everywhere in the plenum. So now days, I don`t look at what`s new and what`s not, I`ve bought new parts that were no good countless times. I bought a MSD HEI module that wasn`t any good, a Accel HEI super coil that put out spark so weak when it got to 4000 RPM it started busting, accel spark plugs fresh out of the box and 2 of them were bad. It`s just been my experience, just because it`s new, don`t rule it out.
Old 05-20-2010, 11:03 AM
The first thing I would do is plull the offending plug....hook it to the wire.....have your buddy crank it over and see what the plug is doing and go form there.
Old 05-20-2010, 11:25 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Make sure the cap is wired 1-8-4-3-6-5-7-2, and that #7 and #8 aren't switched.
Old 05-20-2010, 12:22 PM
kk, i'll try some things out and get to y'all asap
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 06:57 PM
Buick 430 Engine 70LEBUICK Engine 5 02-24-2010 09:57 PM
Build for Hp or Torque? Venturat Engine 76 09-23-2008 10:22 AM
1985 C-6 truck tranny, no engine braking effect fast68 Transmission - Rearend 40 02-04-2008 05:55 PM
Engine Missing 59fordf100 Engine 6 04-19-2005 09:34 PM
