Motor mounts are cheap. Usually 10-20 bucks. Lift the engine out a few inches and do both. Not a bad job by any means, especially with two people. Probably take a few hours. A 12 pack of rootbeer should suffice.
Broken motor mounts can cause bad vibrations. However there are lots of other things on an engine/chassis that can as well.
Bringing history and technology together. |
The way to check and see if the mount is broke is to put it in gear and hold your foot on the brake. Give it a little gas and watch the engine. It will lift right up. Do it in forward to check one mount and reverse to check the other. Some mounts have a metal restriction to only allow a small movement. Watch for this. You should be able to shine a bright flash light at the mount and see it seperate if its broken.
