Engine mount question? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-14-2011, 09:18 AM
Just installed must II IFS. I have a Chassis engineering eng cross member, w/ 8in drop. I am thinking to but it up right against my must II cross member, weld it where it touches and of course at each end to the frame! My firewall seems a bit close, I will have to trim, (putting 350 sbc) Any suggestions I am open to advise, thanks, Dana, (pic would be welcome)
Old 08-14-2011, 10:33 AM
327NUT's Avatar
As you said.....pic would be welcome, hard to give suggestions w/o seeing the set up. I'm assuming the new mtr mounts are on the new cross member?
Old 08-14-2011, 12:25 PM
My chassis eng crossmember does have the eng mts attached (the eng mt is a complete seperate piece) It is what chassis engineering sells, 6,7, or 8 inch drop! Mine is the 8 in drop.
Engine mount and cross member question luckynumberslevin General Rodding Tech 2 12-23-2010 11:16 PM
Engine mount question v8muscle Engine 2 07-16-2008 07:12 PM
SBF into Dogde D50 engine mount question.. Deep Sleep Engine 1 02-21-2006 07:20 AM
engine mount question pigjamelectric Engine 8 06-23-2005 03:01 AM
Engine Mount Question Nightfire Hotrodding Basics 5 04-01-2004 10:15 AM
