Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Engine Mount Question
Old 03-31-2004, 03:16 PM
BOBCRMAN@aol.com's Avatar
BOBCRMAN@aol.com BOBCRMAN@aol.com is offline
Do not use solid mounts on a street car that is going to be used on a constant basis. Metal fatigue from the constant twisting will rear its ugly head. Usually at the worst moment. As for the motor mount dimension, there are several different mount arrangements used thru the years on small Chevies and each series has different widths. The late sixties/early seventies are the narrower style.
