Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - engine mounting
Thread: engine mounting
Old 10-28-2012, 09:31 AM
MARTINSR MARTINSR is offline
The frame is symmetrical if that is what you are saying, it is the same from side to side.
If you have any doubt, cross measure it like this.
If you are using the same points side to side and you cross measure and the distance comes up the same, you are good to go.
Then using those control points that you have confirmed to be the same on both sides by your cross measuring.
