Engine mounting - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-24-2003, 04:53 AM
Dutchman's Avatar
Old Salt
Engine mounting
I understand the LS1 engine mounting is a little different and an adaptor is needed to mount an LS1 on a older chassis regular chevy 350 mount.
So, my main questions is do the LT1/4, Ram Jet 350 and 350 block engines mount all the same in dimensions and measurement and are they interchangeable?
Dutch
Old 08-24-2003, 07:35 AM
BOBCRMAN@aol.com's Avatar
All the small block Chevrolets built before the advent of the LS-1 were physically the same with the same engine mounts, less the first 55-57 blocks, which had no side mount bosses cast in the block.
Old 08-25-2003, 02:12 AM
Dutchman's Avatar
Old Salt
Thanks BOBCRMAN! That helps allot with the set up for my chassis.
Dutch
