engine mounts - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-12-2012, 08:37 AM
engine mounts
I'm installing a 1968 Nova 250 c.i. inline six in my 1947 Frazer. Question: any ideas of how I can mount engine mounts on the front of the block as opposed to the side mounts as in the Nova? Any help would be appreciated!
Old 07-12-2012, 09:20 AM
front and rear engine mount
look at marine application for idea's
Old 07-12-2012, 03:36 PM
engine mounts
Thanks! I'll pursue this. Someone also mentioned possibly using 158 Corvette mounts. I'll explore both.
Old 07-12-2012, 09:35 PM
RWENUTS's Avatar
Hurst motor plate. You can even build your own. Some ideas in this link.
SBC Hurst Motor Mount?? - THE H.A.M.B.
Old 07-13-2012, 07:27 AM
motor mounts
You guys are amazing! Thanks for all the advice. I'll post photos when done!
Old 07-13-2012, 07:34 AM
Wiki Edits: 27
mid mounts
It's best to use the mid engine mounts, if you use front mounts then you will need belhousing mounts, and should use a trans with a short tailhousing.
Engine Mounts juiced66malibu Hotrodding Basics 4 04-26-2010 10:29 AM
engine mounts joeyb Engine 2 01-19-2010 05:42 PM
MOTOR MOUNTS (Engine Mounts) PackMule General Rodding Tech 2 08-28-2009 09:52 AM
bb engine mounts for 56' DaSouthWon Engine 1 05-08-2006 12:55 PM
engine mounts Camaro76 Engine 1 02-15-2003 02:57 AM
