Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - engine mounts on a 65 nova
Old 09-11-2005, 07:52 AM
Frisco's Avatar
Frisco Frisco is offline
Glad To Be Here
Originally Posted by hot_rod_kid
hey everyone. I have a question regarding the motor mounts on a 65 nova.
The car has a straight 6 cylinder and I am soon getting a 327 to replace the 6 cylinder. I have heard that the engine mounts will need to be moved back to allow room for the 327.
my questions are, is the moving of the mounts required? will the straight 6 mounts work or will i need to get new ones?
thank you.
Alex
The 6 cylinder frame mounts will not work with the V-8 engine. Use part # 01007 from Chevy II Only. The trans crossmember will also have to be changed as well as the radiator. The oil pan will have to be changed as well. Go to Chevy II Only and you can search online at that site for the parts you will need. They also have a complete kit for the V-8 installation.
My son is doing the same conversion on a '65 Chevy II wagon. Good luck and ENJOY!
