Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Engine mysteriously died, need suggestions please
Old 08-27-2007, 05:14 PM
docvette's Avatar
docvette docvette is offline
Wiki Edits: 12
Doc here,
What COLOR is the spark at ALL the plugs?
Run a jump start cable clamped to the battery to the intake manifold, and try to start again..If it does install a NEW Ground buss system.
RUN a jump wire from THE battery to the HEI + and try and fire..If it runs you have an open in the ignition system..troubleshoot and repair..IF not..
Pull the module, and have it tested, replace as needed.
Do an ohms check on the Coil primary for "in Spec" readings.
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
