Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Engine not running happy upon first start up
Old 11-12-2012, 08:20 AM
66GMC's Avatar
66GMC 66GMC is offline
Get in, sit down, hang on
Last journal entry: Cab Removal
Just one or two.
If this is a flat-tappet cam, make sure that your engine is well-primed (i.e. oil coming from all rocker arms), and that you have added some ZDDP additive.
If you're running dual springs on your valves, you should remove the inner springs to reduce the spring seat pressure. (You won't need them at this comparatively low RPM range.)
