Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Engine not running happy upon first start up
Old 11-12-2012, 10:46 AM
evilbeef54's Avatar
evilbeef54 evilbeef54 is offline
Almost Done... hahaha
Originally Posted by 66GMC View Post
Just one or two.
If this is a flat-tappet cam, make sure that your engine is well-primed (i.e. oil coming from all rocker arms), and that you have added some ZDDP additive.
If you're running dual springs on your valves, you should remove the inner springs to reduce the spring seat pressure. (You won't need them at this comparatively low RPM range.)
okay thanks I did use the break in additive. At this point since it already ran shouldn't it already be primed? Also i am not using dual springs
