Originally Posted by evilbeef54
I have triple checked the wires are all correct, brand new plugs, the timing should be at about 10* at idle with the vac advance line removed from the carb and plugged correct?
i will check for leaks
i will double check the valves before i start it up, thanks
think the idle timing should be a bit more than 10d.
why have you removed the vac adv line from the carb to dizzy ( or have i read that wrong ? )
