Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Engine not running happy upon first start up
  #49 (permalink)
Old 11-15-2012, 01:32 PM
mustang 671's Avatar
mustang 671 mustang 671 is offline
just had a thought . not sure how yours works but my dizzy ( not being used now - only to drive oil pump ) has a helicol drive cog which locates off of the cam. if that is buggered or the spilt pin is screwed it may turn for a bit but then fire wrong due to the spilt pin or dodgy teeth on cog etc etc. put a rag around the cog and try to twist gently with the dizzy locked. or best still replace with a new pin to be on the safe side,
The Following User Says Thank You to mustang 671 For This Useful Post:
cobalt327 (11-15-2012)
