Originally Posted by 66GMC
I was going to say this earlier, but really ...
BOTH diagrams give you the exact same information ... same cylinder numbering, same firing order, same distributor rotation and terminal layout.
That being said, I do prefer the clarity of purpose in the second diagram.
That is correct but only if you install the dizy so the rotor points to where the #1 WIRE will be, most of the info everywhere says to install the dizzy so the rotor points to the #1 cylinder, if you did that then installed the wires so that they line up like picture #1 you would be off
