Engine not running happy upon first start up - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 11-13-2012, 07:31 PM
evilbeef54's Avatar
Almost Done... hahaha
why do some diagrams show the wiring like this
and some show it like this:
I did it the second way, with the rotor pointing at 1, and the wire on the cap post pointing at 1, i am non HEI points style
  #32 (permalink)
Old 11-13-2012, 08:05 PM
123pugsy's Avatar
Last wiki edit: Metal shaping
Wiki Edits: 29
Maybe its time for a compression test.
  #33 (permalink)
Old 11-13-2012, 08:11 PM
healthy & repeated backfiring thru the carb is one of 2 things:
1. A spark plug firing way too soon (like when the intake valve is open) - wires not routed properly.
2. A intake valve not closing, or open at the wrong time.
At this point, you need to make sure you are getting good even compression on all 8 cylinders. This will also tell you if the cam is lined up properly.
Do a compression test at this point.
The Following User Says Thank You to tjet For This Useful Post:
techinspector1 (11-13-2012)
  #34 (permalink)
Old 11-13-2012, 08:17 PM
evilbeef54's Avatar
ok, thanks
  #35 (permalink)
Old 11-13-2012, 08:36 PM
evilbeef54's Avatar
got a guy from work who is pretty good with all this stuff swinging by tomorrow afternoon to help check it out, we will be doing a compression check and checking out the distributor so make sure everything is okay with that, damn this is frusterating, everything i have read says everything i did was done right so far as i can see, hopefully a fresh set of eyes will help, time to forget about this motor for 24 hours and play the new call of duty, lol
  #36 (permalink)
Old 11-13-2012, 09:10 PM
Good idea, get a 6 pack too. I like Red Alert 2 when I need to take a break.
  #37 (permalink)
Old 11-13-2012, 09:21 PM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
Originally Posted by evilbeef54 View Post
I like it with #1 at 5:30 PM as shown here. Seems like it provides the most room at the manifold and firewall when you're swingin' the vacuum cannister around.
  #38 (permalink)
Old 11-13-2012, 09:53 PM
evilbeef54's Avatar
that is what i have always done, an what i did again this time... just making sure...
  #39 (permalink)
Old 11-13-2012, 09:54 PM
evilbeef54's Avatar
lol, for sure, never hit the store after hitting game stop today, so it is a vodka and rootbeer night will start over after work tomorrow... where is that reset button for the last few days, lol
  #40 (permalink)
Old 11-13-2012, 10:21 PM
Senior Curmudgeon
Wiki Edits: 326
It's in the bottle somewhere.....
  #41 (permalink)
Old 11-13-2012, 11:08 PM
evilbeef54's Avatar
for sure, lol
  #42 (permalink)
Old 11-14-2012, 12:08 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
You've heard this before I'm sure, but it really makes no difference what terminal is #1 as long as the firing order is correct.
You can reconnect the vacuum advance. It isn't likely to be the problem, but the engine needs to have plenty of advance, so hook it back up!
A points-type distributor can give you all sorts of problems. Has the dwell been checked? What about the plugs- they should be fresh, too.
Curious to see what the compression test tells you.
  #43 (permalink)
Old 11-14-2012, 11:13 PM
evilbeef54's Avatar
compression test tomorrow he forgot to bring the tester today, lol, will post up results, however he did stop by and checked out the dizzy and thinks it is pretty jacked, the vac advance can is stuck and doesnt want to move, it looks like it is pretty far out of adjustment and pretty dirty, i am sure i can just replace the can and clean it up, hopefully this is what is leading up to all the issues, gonna try a different distributer tomorrow and see if all is solved.
  #44 (permalink)
Old 11-14-2012, 11:18 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Mounts
Sounds like an opportune time to upgrade to HEI.
  #45 (permalink)
Old 11-14-2012, 11:25 PM
evilbeef54's Avatar
thought about it, HEI doesnt look like it will fit with the tight clearance on the firewall, however i found a local guy that has a MSD pro bilet, with 6a box, wires, and upgrades for great price
won't start after running HARVICKx29 Engine 5 01-28-2013 02:56 PM
running rich and smokes at start up elcaminodragster Engine 17 08-22-2012 07:11 PM
89 GM TBI 350 - Quit Running...Where to Start? Rambo_The_Dog Engine 10 05-18-2007 06:21 PM
Won't start after it's been running for a while shawn7 Engine 25 11-27-2006 04:34 AM
why would great running carb just start acting up? bullheimer Engine 6 04-13-2006 02:31 PM
