Engine not running right after long term storange - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-16-2013, 08:59 PM
I have a 69 396 BB engine. The engine was totally rebuilt 10 years ago and I installed new rod bearings, rings, mild performance cam with timing gears, and ground the valves and seats. When the engine was fired up it ran like a fresh motor, not issues. It had a stock points ignition and a 4 barrel Qjet.
The engine then sat for 8 years due to unexpected issues in life. I rebuilt the carb to insure no stale gas/varnish issues. Upgraded to a new HEI distributor and new wires. I insured that the distributor was installed correctly ( #1 at TDC with rotor pointing to #1 tower). Fired it up and the vacuum gauge fluctuates rapidly between 11-14 inches. It occasionally backfires through the muffler. Adjusting the timing does not improve the symptoms. Any ideas on the root cause? Sticking valves?
Old 06-16-2013, 09:18 PM
Faith - Respect - Trust
Sticky valves could cause rough running but, my concern would be the vacuum, check for vacuum leaks, could be caused due to gaskets (intake gaskets) shrinking and leaking. Try running the engine and spraying a product like wd48 on the intake and head mating surface for example...if the vacuum gets more stable, you have found your problem.
Hope this helps
Ray
Old 06-16-2013, 09:51 PM
TonkaYJ's Avatar
Last journal entry: Took her out for a drive Oh Ya! Gotta Love an LS powered early Vette
do you have a new wire ran to the dist Batt. wire needs full 12 v the stock wire to the coil + is a resistor wire and has only 9v ? vauum bounce with rpm could be a stuck valve
Old 06-16-2013, 10:35 PM
Banned
Could be a goofed carb rebuild. Very easy to do and it was the only thing that was changed.
Just Joined, Have Several Long Term Projects DAD128 Introduce Yourself 1 12-28-2011 04:26 PM
Long Term Storage Mike1971pu General Rodding Tech 14 04-06-2009 08:30 PM
long term primer chevyman992002 Body - Exterior 16 05-05-2005 12:36 AM
Long Term Engine Storage 6T5FIVESPD Engine 10 01-12-2004 05:51 PM
