engine numbers - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-03-2009, 09:41 PM
engine numbers
im looking to buy a good 350 to build into a 383 stroker with 500 plus horses and place in my 1985 chevy.. im looking at this specific engine and im wondering if it is a good motor.. im new and i cant tell if its a 350 or not... the numbers on it are 3970010 v0708cmj 15j253166 help?
Old 05-03-2009, 09:42 PM
DaSouthWon's Avatar
I put up the tools against$300
www.mortec.com
Old 05-03-2009, 09:47 PM
fast68's Avatar
likes chevy trucks & boobies
howdy there 3970010 and cmj is 350
ive owned a billion cmj stamped 350 engines over the years
it has to be about the most common 350 stamping out there
and 3970010 is probably the most common 350 casting as well about 95% of all the ones i have had have been this casting code
welcome to HR forums
have fun!
Old 05-03-2009, 09:51 PM
have fun!
you wouldnt happen to know if its a 2 or 4 bolt main would you... just by looking at the numbers? or is my best bet taking the oil pan off.. btw where can i get my hands on a set of 2482 main caps?
Old 05-04-2009, 08:38 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
You'll need to take a look to see if it's a 2- or 4-bolt.
I don't know about "2482" caps, but if you're thinking of using different caps on a 350, your best bet is to start w/a 2-bolt block and convert it to 4-bolt caps- using splayed caps.
Old 05-07-2009, 02:23 AM
DoubleVision's Avatar
Keep in mind also if you switch main caps the block will have to be line bored. A 2 bolt block with studs that`s line honed will handle 500 horses. If this is a basic street machine you maybe setting your goals on the high side.
Old 05-07-2009, 06:14 AM
2000jack's Avatar
1929 Chopped Tudor
Last wiki edit: How to title a hot rod
Last journal entry: 1927 roadster
Wiki Edits: 3
I am not going to guarantee this, only what some one said and I have noticed this to be true a couple of times. So if it is not correct I don't want to here a bunch a people emailing in calling me an idiot (I already know that). Right above the timing cover , facing it, on the block, on the left, if there is a screw in plug around a 1/4 inch diameter with a square head then it is suppose to be 4 bolt. Again read the first line!
Old 05-09-2009, 08:26 PM
fast68's Avatar
howdy there again
well, you will never know if its a 2 or a 4 bolt main bolt block until you pull the pan and look.
most likely it is 2 bolt because it is a car block of the '70s era.
and most car ones of this era were 2 bolt i have found
from my own experience of owning and seeing this casting and stamping suffix code 350 engines over the years
most blocks have this oil gallery plug you speak of,
nothing to do with main bolts quantity
splayed 4 bolt will be the best strength, although splayed it not stock. otherwise 2 and 4 bolt in stock form really are virtualyl the same strength,
and besides, only the three middle main caps are 4 bolt
but if you want a factory 4 bolt main block then find a truck 397001 or 3970014 etc., unless you can manage to find a high HP car application 4" bore block, but good luck there. getting rare these days.
converting a block to splayed mains would be the way to go if you are concerned with strength., although main strength is not an issue with sbc engines, and very rarely is.
weak points to worry about will be other things, such as crankshaft material, and rods, etc.
have fun!!
Old 05-09-2009, 10:08 PM
2000jack's Avatar
1929 Chopped Tudor
Wiki Edits: 3
howdy there again
have fun!!
I had some one tell me this about the "oil gallery plug" and the 4 bolt main, since then I have seen two 010 blocks with the plug and they both had 4 bolt mains and one with out and it was a two bolt main block, I don't know maybe just coincidence. But I will keep looking just out of curiosity. It probably doesn't make difference so that is why I said I did not know in my first post. If it was true I thought I would have heard about it a long time ago. I agree with you 100% about difference in strength of a two bolt and a four bolt block " main strength is not an issue with sbc engines, and very rarely is."
engine serial numbers (ford) rubyqq Engine 2 08-06-2007 03:59 AM
Engine numbers D'OnneSmith Engine 1 03-04-2007 11:20 AM
cadillac engine numbers dragsternut Engine 0 02-22-2007 08:31 AM
Engine Identification Numbers cobraone Engine 0 02-22-2004 12:06 PM
engine numbers ? andrewcdennis Engine 3 06-03-2002 08:36 PM
