Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Engine oil cooler
Old 02-15-2013, 01:33 PM
thinwhiteduke's Avatar
thinwhiteduke thinwhiteduke is offline
Living In The Past
I'd be more concerned about what is causing the engine to run hot to start with. Cooling the oil off, or attempting to, is not going to solve the problem.
If I were you, I'd be focusing more on the cooling system, to start with, and other factors like plug heat range and ignition timing, than the oiling. Retarded ignition timing will cause an engine to run hotter.
Duke
The Following User Says Thank You to thinwhiteduke For This Useful Post:
vinniekq2 (02-15-2013)
