Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Engine oil cooler
Old 02-15-2013, 02:14 PM
cobalt327's Avatar
cobalt327 cobalt327 is online now
WFO
Wiki Edits: 1616
Unless you're adding the vacuum advance in, 45 degrees BTDC is way too much timing.
Be sure the timing tab and damper line are accurately showing TDC- which may not be the case.
